question?
Old Jun 20, 2007 | 11:25 PM
396Z28's Avatar
Default question?
For all you guys running 383's what type of gear are you running and what times are you at in the quarter. Im running a 3.70 gear in my ford nine inch and the best i can get out of it is a 1.7 sixty foot. Any suggestions?
Old Jun 21, 2007 | 12:24 AM
speed_demon24's Avatar
Motor size doesn't dictate what gear you run, tire size and RPM range does. Just gear your car to cross the traps right before you hit the rev limiter.
Old Jun 21, 2007 | 07:54 AM
fast's Avatar
sounds like you need to work on suspension set-up
Old Jun 21, 2007 | 08:58 AM
LT1MAN's Avatar
i agree, a well adjusted suspension setup will net you better 60' times, and 28" tires with 4:10s.
Old Jun 21, 2007 | 10:03 AM
396Z28's Avatar
traction is not a problem it doesnt spin at all but thats just how it comes out of the whole like it needs a bigger gear or something
