383 build
Old Jun 21, 2007 | 11:19 PM
FireBird_Fr3ak's Avatar
Default 383 build
if an LT1 has a spun bearing can i pull it out, clean it out, swap in all http://cgi.ebay.com/ebaymotors/SB-CH...QQcmdZViewItem those parts and will it fire up fine with stock heads/cam/ignition etc...?
Old Jun 21, 2007 | 11:30 PM
Rick Speed's Avatar
no.. the block has to be clearanced for the longer stroke, plus you'll need to have it machined for bigger pistons, send it to a machine shop and get it done the right way then it will run but not perfect because you'll need the pcm reprogrammed to be perfect.
Old Jun 21, 2007 | 11:38 PM
ok thanks, whats the best tuning sofware for LTs?
Old Jun 21, 2007 | 11:41 PM
Rick Speed's Avatar
LT1edit is my favorite... I have it unlimited use but I'm sure you don't live close by. There are cheap ways of getting it done like sending it to pcmforless.com
Old Jun 22, 2007 | 07:02 AM
Imnotfast's Avatar
Lt1edit and Tuner Cat are both great tuning software.
