Few Questions Still...
If it isn't suppose to stay on then what would cause it to not go off?
2. Does anybody have a diagram of the C200 dash harness plug and where all the wires go? It's the large plug with about 50 wire off it right above the drivers kick panel.
Same car as above. 94 Z28.
Thanks,
Mike
There is an orange wire that says it should have constant power and it does. There is a yellow wire that says it should only have power when the key is in the accy/on position yet it has power all the time as well.
Mike
The horn relay clicks when I push the horn button but no sound from the horns.
Thanks,
Mike
