shift light install question
Old Jun 24, 2007 | 03:25 PM
urbanhunter44's Avatar
Default shift light install question
Hey guys
I'm installing a shiftlight into my car, standard power/ground/tach style
I'm having trouble finding a good power wire under my dash, does anyone have a good description of where one is, needs to be a 12 volt that comes on with the ignition.
I've also heard that theres a tach wire coming off the coil, which wire is it? My plug into it has two wires, one appears to be orange, the other a pinkish color.
Thanks for any help
Old Jun 24, 2007 | 06:15 PM
buffman's Avatar
It's recommended to tap into the A13 pin on the red PCM connector. A much cleaner line for a tach/shift lite/etc. 12V power, you can pull off anything. Heck you can prolly pull it off the cig lighter. I mean the lights not going to come on till it sees the desired RPM so it won't be draining any power while the car is off.
Old Jun 24, 2007 | 07:59 PM
dhdenney's Avatar
I have used spade terminals in a couple spots in the inside fuse box.
Old Sep 11, 2009 | 10:38 AM
Lgoldtop's Avatar
what if you have the coil pack on your lt-1 does that mean you need the tach adapter box ?
Old Sep 11, 2009 | 11:23 AM
dhdenney's Avatar
LTCC or Delteq?
Old Sep 11, 2009 | 12:22 PM
Stroked96Bowtie's Avatar
My .02, I ran mine to my 6al then for the power I took my fuse panel door off and tested links with a test light till I found one that only powered on when the key was on. Wrap your power wire around that fuse and stick it back in its hole.
