Harmonic Balancer Crank Nub
Old Jun 29, 2007 | 12:03 PM
ss44's Avatar
Default Harmonic Balancer Crank Nub
Are there any tricks to pulling this off? We've broken 2 harmonic balancer pullers trying to get this off. We've taken LS2 balancers and SB1 balancers off no problem but so far it's
Crank Nub: 2
Harmonic Balancer Pullers: 0
Attached Thumbnails Harmonic Balancer Crank Nub-0629071252.jpg   Harmonic Balancer Crank Nub-0629071254.jpg
Old Jun 29, 2007 | 12:54 PM
Speed Density's Avatar
hashtagBMW
I rented a steering wheel puller from Shucks. That plus a rubber mallet and it pops right off.
Tony.
Old Jun 29, 2007 | 01:57 PM
ecksz28's Avatar
I've used the puller kit from O Reilys before. It works... and would suck if you broke it.
Old Jun 29, 2007 | 02:47 PM
infinitebird's Avatar
There's an easy method to this that always works for me.
Get a regular 3 jaw puller at any auto parts store (like $15-$20) ex. http://www.cumminstools.com/browse.cfm/4,382.html
Then get a long bolt (I think a 5/16, but the widest you can fit in the center hole of the hub) and drill a small recess in the head of it so the puller tip can press against it without slipping. Then insert the bolt into the hole with the puller tip on the head and attach the puller arms to the 3 extensions of the hub and turn it.
However you do it, the key is that the primary force has to be pushing in the hole against the crank and not pulling out toward you on the hub.
Old Jun 29, 2007 | 03:50 PM
ss44's Avatar
We figured it out. Thanks guys Long story short we're a couple of tards.
Old Jun 29, 2007 | 03:58 PM
69gto96z's Avatar
I went through the same thing yesterday. I could NOT get the hub off, then I realized that the bolt needs to be in. I was pulling on the hub at first, with the pushing part of the puller pushing on the hub also.
Old Jun 29, 2007 | 04:27 PM
ss44's Avatar
Yep. Exact same thing we were doing. Explained why we broke 2 pulley pullers before we figured it out.
