Is this the scanner I need?
Old Jun 29, 2007 | 05:28 PM
Silver2000WS-6's Avatar
Default Is this the scanner I need?
Is this the scanner I need if I want one for help on tuning my 97 ta? This and LT-1 edit is all I need RiGhT? Thanks
http://www.autotap.com/product.asp?S...TrailType=Main
Old Jun 29, 2007 | 05:39 PM
dhdenney's Avatar
I thought you get a scanner with LT1 Edit? There are different levels you can buy and I think I got the higher one. It had scanner with logging.
Old Jun 29, 2007 | 07:12 PM
infinitebird's Avatar
AFAIK lt1edit does not come with a scanner, unless they've added that recently.
For the autotap scanner, go to this page: http://www.autotap.com/product_family.asp?FamilyId=260
and you need either the ATS or ATU ($199, ATU = usb, ATS = serial) and the option to add GM enhanced parameters ($99).
Old Jun 29, 2007 | 07:38 PM
dhdenney's Avatar
I use my LT1 Edit scanner all the time. Had it since 2003.
Old Jun 29, 2007 | 08:34 PM
They have a scanner for obd1 (your car is a 94?, in your sig) but not for obd2. The OP has a 97 which is obd2. Autotap is the only obd2 scanner I'm aware of that can log all parameters.
Old Jun 29, 2007 | 08:38 PM
dhdenney's Avatar
Oh ok that's the difference. I assumed that since they had a scanner for OBD1, they'd have one for OBD2. Kinda odd they don't.
Old Jun 29, 2007 | 08:43 PM
Probably because it's much easier to write a scanner for obd1. There are several scanners for 1 freely available on the net, they might have even gotten theirs from someone else.
There's no free ones available for 2 though, unfortunately.
Old Jun 29, 2007 | 08:50 PM
dhdenney's Avatar
I had never looked for an OBD2 scanner because, well, I never needed one.
Old Jul 3, 2007 | 04:44 AM
koolaid_kid's Avatar
LT1Edit for OBDII has not been supported for years, which is probably why they never bothered to write one.
I use AutoTap for Windows, with a USB port to my PC.
I wonder how much data you could see on a Palm?
It is nice that they include the enhanced parameters, but it does appear that you also need another cable as well, and possibly a null modem.
Personally, if I had it to do over, I would get the Jet software over the LT1Edit. It is still supported, and the interface I saw had more options than LT1Edit.
Old Jul 3, 2007 | 08:30 AM
Thanks guys..
