How to oil prime an LT1
Old Jul 3, 2007 | 06:34 PM
z28ss4me's Avatar
Default How to oil prime an LT1
Just wondering, I've got a 95 Z28, that hasn't been started for about a year and half. What I need to know is how I can turn the oil pump to lubricate the motor and crankcase before attempting to start it the first time?
Old Jul 3, 2007 | 07:09 PM
wrd1972's Avatar
Pull the coil wire and pull he two fuel injector fuses from the underhood fuse box. Crank the engine over for about 10-15 seconds, his should build the pressure. Repeat the process as long as you allow some time for the starter to cool off since this will get it toasty.
You could even pull the oil pressure sensor and look for oil if you are really concerned.
Replace wire and fuses and fire it up, you should be fine.
aboatguy's Avatar
You'd have to pull the intake. I'd take the chance and start it. (But I'm in the Navy and have had cars sit for long periods IE 3 months to 3 1/2 years and never spun a bearing)
Mike
Old Jul 3, 2007 | 08:10 PM
NotACop97Z's Avatar
you should be alright if you pull the coil and fuel fuzes
Old Jul 3, 2007 | 08:26 PM
Imnotfast's Avatar
You dont have to pull the coil wire or the fuse. Just unplug the opti plug at the intake and hit the starter. Or pull the intake.
Old Jul 3, 2007 | 08:48 PM
wrd1972's Avatar
Yes that will work too. Just don't damage it.
Old Jul 4, 2007 | 12:29 AM
z28ss4me's Avatar
Thanks for the info folks, I'll give it a shot.
