while driving runs cool at idle gets hot?
thanks,
Brett
Mine used to do that, then i got the 160 thermostat + pcm tune to turn the fans on sooner. the car's temp does not move from one quarter the way up, ever.
A lot of people aren't aware that the stock lt1 cooling system will often run to 235 sitting in traffic. 235 is when the 2nd fan turns on and in the hot summer months this is often what's needed to stop the temp from going up any further.
Reducing the fan temps or installing a switch is a good solution.
Get the 160* thermostat and a tune to turn the fans on early.
If you don't have one, get one and pick up some HP while you are at it.
