porblems, help!!
1. When i turn hard to the left i hear kind of like a screeching sound maby like a rubbing of calpiers but its only from what i can hear in the back right...? and it also makes sounds when coming to a stop or starting off, not when on the breaks...?
2. When im in either 5th or 6th gear i hear and feel a sound which seems to be in the rear or driveshaft, it only does this above 70mph in those 2 gears. i think it might have somthing to do with bad gears b/c i noticed when i step on the acelerator i can kind of feel some grinding and it doesnt pick up as fast...?
any help would be great thanks
I shimmed my Rear Calipers away from the Axles, they made a scraping sound going around corners, and I found that they were too close.
