lifter problem on a LE2 TA
Old Jul 7, 2007 | 08:38 AM
97TAWS6's Avatar
Default lifter problem on a LE2 TA
I have a 97 WS6 trans am wit the LE2 heads, cam, and ported intake. I have comp cam R lifters that keep breaking on me. What happens is the internals of the lifter pretty much shoot out of the lifter. I rev my car to 6800 Rpm and am not sure if that is the problem or not. My question is why this is happening and what lifter would you get to replace the comp cam r's cause i know others were having problems with this lifter. Thanks in advance.
Old Jul 7, 2007 | 08:45 AM
z28_theantirice's Avatar
ls7 lifters or the caddy ls7 lifters will solve your problem guaranteed alot of bang for your buck there
Old Jul 7, 2007 | 08:53 AM
97LT1's Avatar
^^^^agreed
Old Jul 7, 2007 | 09:32 AM
Michigan Skip's Avatar
How much do you crank down to adjust the lifter? i.e. 1/4 turn,, 1/2 turn etc past zero?
Old Jul 7, 2007 | 09:56 AM
Old SStroker's Avatar
What did Lloyd Elliott say when you asked him?
Old Jul 7, 2007 | 09:57 AM
scorpion_z28's Avatar
Where can u get those lifters? i tried searching but nooo luck finding them
Old Jul 9, 2007 | 10:29 AM
come on people some help plzzzzzzzzz
Old Jul 9, 2007 | 10:53 AM
speed_demon24's Avatar
How much preload are you running?
Old Jul 9, 2007 | 06:06 PM
http://www.sdparts.com/ has them, you can also order them through GM Parts Direct because they are a gm part
Old Jul 9, 2007 | 09:49 PM
seawolf06's Avatar
Get rid of those lifters asap. You're probably running way too much preload which kills them. I'd go with the Caddy Racing lifters for the LS7 if you can find them. There are a few threads on here about them.
