nitrous dosent help... i just put nitrous on my car and ran it a few times...my car n/a runs like 13.8s@98-100mph in the heat..with the spray..a 150 shot..its running a 13.4@110...idk why its not working...i have a fogger nozzel in the stock intake elbow...i have the bottle pressure up around 1100psi..everything works fine..plugs are gapped correctly..but the 2 time i ran the car it didnt really show a big improvment..what can cause this..or is the heat just killing me |
you probably have something not hooked up correctly.. im sure someone with some experience in this will chime in soon. it could be that you jst have the wrong jets for the kit. |
are you sure you're actually spraying nitrous when you hit the button? is it a wet or dry kit? sure you have the 150 jets in it? |
Yeah I would take the line off the front of the solenoid and trigger it to see if it's squirting nitrous. Don't want to fill up the motor with nitrous and it not running cuz you'll have a time bomb when you start up! |
its a wet kit..i have the rite jets...all the connections are right..and i feel the car move when i spray it...i still have the stock intake elbow..could it be that wen it sprays the nozzel moves and isnt going directly into the intake? or could i not have enough fuel pressure and im spray just nos? |
Originally Posted by Lt1CamaroSS i just put nitrous on my car and ran it a few times...my car n/a runs like 13.8s@98-100mph in the heat..with the spray..a 150 shot..its running a 13.4@110...idk why its not working...i have a fogger nozzel in the stock intake elbow...i have the bottle pressure up around 1100psi..everything works fine..plugs are gapped correctly..but the 2 time i ran the car it didnt really show a big improvment..what can cause this..or is the heat just killing me |
Originally Posted by 69gto96z Sounds like its working to me, 13.8 at 98 compared to 13.4 at 110, your MPH is there which shows its working, sounds like you have a traction issue or your not gettin out of the hole good enough. My car ran a 9.0 bone stock in the 1/8th, and a 9.4 full bolt one with a 150 shot....My mph was way up, but traction wasnt there and killed my time. whoops. didn't notice the mph increase :cool: |
lol well that whole 2mph increase really doesnt seem fair for a 150 shot on a car running high 13s... i would have expected to be damn near 12s if i was him.. if not a high 12.. |
Originally Posted by z28hustle lol well that whole 2mph increase really doesnt seem fair for a 150 shot on a car running high 13s... i would have expected to be damn near 12s if i was him.. if not a high 12.. |
Originally Posted by 92LT1RS whoops. didn't notice the mph increase :cool: |
Originally Posted by z28hustle lol well that whole 2mph increase really doesnt seem fair for a 150 shot on a car running high 13s... i would have expected to be damn near 12s if i was him.. if not a high 12.. yeah, 98 mph NA to 110 mph on the juice, thats the largest 2mph increase i ever seen :judge: |
ya....user error |
in the heat im anywhere from 2.10-2.30...the car dead hooks and the whole 1/8th is slow..im launching to hard so the car just dies..im spraying manualy off the wot switch..i dnt have the window switch..so im controlling it with the activation switch..i think the heat and the launch is just killing my 1/4mile...i have stock 3.23's and stock converter..so out of the whole takes off alot at top..in most case's...every 1 thousandth in the 60ft is 2 at the top |
The nitrous is working fine, you can easily tell by the 12mph increase. What isn't working is your stock stall...you need to get an aftermarket one and you should look into some 3.73 gears. Edit: Not to be an ass but 2.10-2.30 is a pretty horrible 60ft, that is why you have a crappy et and please tell me you have a real tune and not just the hypercrap for the spray... |
lol...well when the air was good in the beginning of the season i was in the 1.9s...the car just has launching issues...it has a pcmforless tune |
Yep your NOS is workin Definitely need to get rid of that stock stall and get lower gears 3.73's or higher and your ET will probably pick up a second. |
Oh ok, what type of tires do you have on there? My car was practically tractionless until I got lower control arm relocation brackets, they made a world of difference. Ah good just making sure about the tune lol. It sounds like you just have a mismatched combo at the moment with the 3.23 gears and stock stall, take care of that and get 12s easily. |
cooper zeon's |
Originally Posted by Lt1CamaroSS cooper zeon's Without a stronger rear and slicks higher gears will not do you too much good with nitrous. Will just spin up a smoke show if you spray off the line, and will give up potential gains if you spray later on. |
yea i didnt do the mph right.. brain fart anyways yea hook up that 60 foot like everyone says.. and stuff.. |
© 2024 MH Sub I, LLC dba Internet Brands
