SES light problem
Old Jul 17, 2007 | 07:41 PM
RaM AiR 97's Avatar
Default SES light problem
Me and a friend had just swapped out the A4 to a M6. The car is a 95 formula my question is that when the car turns on it shuts down by its self like as if their was not enough gas for the engine. The thing is that if i give it gas and let off of it constantly it stays on it seems to be missfireing but once the SES light comes on the missfire seems to go away then the car is at a steady but low rpm
Old Jul 18, 2007 | 05:26 AM
infinitebird's Avatar
Did you put in an m6 tune with it?
Old Jul 18, 2007 | 05:38 PM
RaM AiR 97's Avatar
no i havent reflashed to pcm do you think that could be the problem. i know that not all cars are the same but a friend of mine did the same thing with no problems. It just seems very weird that the car doesent missfire once the ses light comes on.
Old Jul 18, 2007 | 05:43 PM
yeah, pretty sure that's the issue. you need to load an m6 tune. the ses is the computer try to figure out why it can't shift the trans.
Old Jul 18, 2007 | 05:55 PM
RaM AiR 97's Avatar
i forgot to mention that i checked fuel pressure changed fuel filter plugs wires coil ignition control module. I am kind of in a slump with money but i will reflash and see if that is the problem. Infinittebird where do you think i would be cheaper to get a reflash dealer or someone that should retune the computer. Did you experience the same problem or have you heard of this
Old Jul 18, 2007 | 08:15 PM
stay away from the dealer ($$$) hit up any of the mail order tuners and they can do it for you.
