Advantage of an LT1 block vs SBC block...
Old Jul 18, 2007 | 02:29 PM
Slow Z28's Avatar
Default Advantage of an LT1 block vs SBC block...
is there any? i'm not talking about strength(or lack there of in a stock LT1 block vs aftermarket SBC)
what would be a reason to keep an LT1 block when converting to a SBC head, if it was in a carb'd race-only type setup.
Old Jul 18, 2007 | 03:00 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
reverse cooling ???.....
Old Jul 18, 2007 | 03:20 PM
Slow Z28's Avatar
how much would that be worth... hp wise.
let's say a VERY restricted class for all motor. where every little bit helps, it could possibly add a few hp to the mix. we are looking for about 550-600rwhp all motor with about 360 cubes.
Old Jul 18, 2007 | 03:57 PM
slick1851's Avatar
Look at what stock eliminator LT1s are doing
Old Jul 18, 2007 | 04:20 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
it will let you run more compression due to cooling the heads first...not sure on exact HP that it is worth
Old Jul 18, 2007 | 05:57 PM
96mikez28's Avatar
anything else guys? i'm scratching my head too
