Had a wreck some major help please
A trailing arm extends from a frame crossmember located ahead of the rear axle back to the axle housing or a wheel knuckle. Trailing arms run parallel to the centerline of the chassis. See FIgure 5-7. (a picture of a TRAILING ARM location). A trailing arm mounts to the frame with bushings, which allows the arm to pivot as the wheel rides over bumps. Some rear suspensions use two sets of trailing arms, one set positioned higher in the chassis than the other. Although the arms in this type of arrangement are commonly referred to as the upper control arms and lower control arms, they are usually called trailing arms. The word trailing applies to any link where the supported member trails the arm. Trailing arms may be used to brace either a driven or non-driven solid rear axle against front-to-rear forces, but they do not provide much resistance to side-to-side, or lateral, forces.
lol Last edited by ThoR294; Jul 23, 2007 at 07:17 PM.
that reminds me of these 2 kids (brothers ugly is what they went by). they decided to try to be cool in the rain in the foxbody mustang, and nailed a curb with their drivers rear wheel... bent the **** out of the wheel.
They put the donut ON THE BACK (mistake #1), and they didnt bother to check the axle, if it was bent at all or not, so they try to drive away... lol. can only guess what happens
