cut wire problem
Old Jul 24, 2007 | 06:15 PM
pointvirus's Avatar
Default cut wire problem
I bought a '95 Z28 around a month ago, and i've been under the hood ever since. The owner before me did a lot of jenky wiring. Some of the wires I've found were poorly spliced together and were causing some problems.
There's one wire that's completly cut and I can't seem to track down the other end. It's a Black/White wire coming right out of the passenger side dash, and looks like it would run to the PCM. I've checked the wires coming out of the PCM for the other end, but nothing. I'm begining to think the other end is missing.
Does anyone know what this wire does or goes to?
Thanks
Old Jul 24, 2007 | 08:09 PM
smoknta's Avatar
I'm not to familiar with the 95's, but it should have a fuel pump prime wire in that area. It usually has a connector on it though. Check out this picture in the link:
http://shbox.com/1/fuel_pump_prime.jpg
Old Jul 24, 2007 | 08:11 PM
FlamingChicken's Avatar
shbox.com has a pin diagram for the pcm connectors. That may help ya. If not i believe he has other schematics. good luck, im in the process of repairing my harness. damn rats got up in there and had fun for a bit.
