Lt-1 Tuneup questions..
Thanks
Zac
As for the milage, if you dont have records I would do it all. Again depending on what codes kick in the system.
Plugs- NGK TR-55's
Plug Wires- Factory, Taylors etc etc
PCV-
Oil chng
Tranny Service
Fuel Filter
o2 Sensors- Ac Delco
As for the opti, it may be or it may not be, run a fuel pressure test, put the guage on, the fitting is in the back of the intake, tape the guage to the window, take it out for a run, it shouldnt drop much, if at all. I wager your pump is dying before opti.
If you need pump I recommend Racetronix
for Opti's and o2 sensors, go to Sam Taylor.
