freakin energy suspension
Old Jul 26, 2007 | 02:26 PM
firebirdhorn's Avatar
Default freakin energy suspension
When installing the energy suspension transmission mount, did any of you guys use the upper preload plate provided with the mount? I did and I think it is the culprit to why I have a crap load of vibration from it. I have been pulling my hair out trying to fix this and I seen a pic on the internet of someone using the same mount but it didnt look like it had the upper pre-load plate attached. Any help would be much appreciated.
By the way, i put it in just the way it tells you to do so.
Old Jul 26, 2007 | 02:30 PM
WhyHelloOfficer's Avatar
The extra plate supplied is not needed. If you are able to do a search (usually its broken), you'll find quite a few threads talking about it. Basically the plate changes the tailshaft angle just enough to where it causes the vibration.
Just take it out and you should be good. Keep in mind also, if you've still got the factory driveshaft, they are known to have a little bit of wobble as well. There was a TSB about them in the Mid-90s where the factory steel shafts would vibrate, and if a customer brought it to their attention they'd replace it under warranty for an alumnium one.
Old Jul 26, 2007 | 04:27 PM
VendettaV6's Avatar
Mine has no vibrating issues, I never used the plate.
Old Jul 26, 2007 | 04:47 PM
urbanhunter44's Avatar
didn't use the plate and I've ran their mounts in every one of my fbodys. No complaints yet
Old Jul 26, 2007 | 09:10 PM
nomoneyz's Avatar
I'm running it with the plate and I don't even notice the vibration.
Old Jul 27, 2007 | 04:56 PM
Vicious95Z28's Avatar
I used the ES mount and murdered it, I now have a prothane that seems more durable
Old Jul 27, 2007 | 07:47 PM
Red96TA's Avatar
Whenever you use an aftermarket trans mount there will be more vibration. You just need to decide whats more important.... hair or trans mount
