What could it be?
I was think the waterpump sprung a leak and got on the opti. I have no idea whats wrong with the car. Any help or advice is greatly appreciated.
i did a spark test: nothing.
Checked fuses and replaced ignition fuse: still turns and turns but no fire
Check to make sure fuel was getting to the motor and it is
Opti? any other possibilities?
I know its not really relevent to your problem, but ours was definitely ignition related (which by the way stopped the fuel too as it works on the same signal).
Did you check the coolant level to see if you'd lost any? (suggesting the water pump did leak).
Sara Lou
