LS1 Airlid Swap -- TRACK RESULTS!!!
Originally Posted by Revelation Z28
the spinning will cause you to run higher mph but lower numbers.
i should be around a 12.9 so youre around a 12.2 with the lid.
Originally Posted by 97bowtie
Spinning doesn't cause your MPH to increase, that's a pretty bad but common misconception. Turning the tires over a little out of the hole is OK because it keeps you from bogging and keeps the engine in the meat of the power band, but if the spinning is so excessive that it's hurting your ET, it's also going to hurt your MPH.
Originally Posted by glocklimited9
this is a k and n fender mount vrs the lid im assuming, not the factory ramair setup vs the lid?
yea, i have a 96ws6 ramair so this wouldnt really matter to me, but i was wondering if the ls1 box is better then my lt1 setup, it looks like there is more to the ls1, not just a box like mine, is that just some sort of silencer setup?
