universal nitrous kit
Old Jul 28, 2007 | 06:50 PM
94Pontiac's Avatar
Default universal nitrous kit
Well I can get a smoking deal on this universal wet nitrous kit part number 05131NOS. Anyone know if' its going to work on my lt1? how is it activated?
thanks
Old Jul 28, 2007 | 07:21 PM
seawolf06's Avatar
You can buy the activation parts separately. You'll need a WOT switch, fuel pressure safety switch and a window switch.
Old Jul 29, 2007 | 10:19 PM
94Pontiac's Avatar
alright, thanks. so it says it comes with a micro activation switch, can that be used?
It sounds like by the time I buy all the activation parts, this kit's gonna cost way more than the right kit..
Old Jul 29, 2007 | 10:24 PM
seawolf06's Avatar
That's the WOT switch. Most kits don't come with all that stuff. Just make sure it has enough line for your car.
Old Jul 29, 2007 | 11:15 PM
94Pontiac's Avatar
http://store.summitracing.com/partde...5&autoview=sku
so it says its delivered through the air intake tube...
Old Jul 30, 2007 | 06:05 AM
jakesz28's Avatar
Yes you can use that kit it is a universal single fogger kit.
Old Jul 30, 2007 | 03:45 PM
scorpion_z28's Avatar
thanks
I've installed this kit on my car but havent used it yet
Old Jul 30, 2007 | 08:12 PM
94Pontiac's Avatar
so where is the nitrous injected? I though wet kits just had a Y in the fuel line...
Old Jul 30, 2007 | 08:24 PM
jakesz28's Avatar
Here are the instructions.
http://static.summitracing.com/globa...-199r10297.pdf (look at page 10)
The nozzle will go in the elbow infront of the throttle body.
Old Jul 31, 2007 | 12:09 AM
94Pontiac's Avatar
thanks! I'll be installing the kit asap. Would you recommend a window switch?
Old Jul 31, 2007 | 06:13 PM
jakesz28's Avatar
Yes since you have a manual tranny. Auto's don't seem to bog that easy. With a auto and a stall I went a year on a wide open switch without any problems. But if it bogs and you go below 2500 or miss a gear it can get expensive.
Old Aug 5, 2007 | 10:15 PM
94Pontiac's Avatar
Ok so I got the kit installed today. The instructions said to mount the fogger on the top of the elbow. I have them tied down as tight as possible but they still hit at the point where the hood is latched but not fully pushed down...
