Balancer removal
Old Jul 29, 2007 | 11:13 PM
alconk's Avatar
Default Balancer removal
I'm changing the cam right now but I'm stuck on the balancer removal?? After removing the three bolts plus the crank bolt should the balancer come off then you can remove the crank hub or is it one piece??
Old Jul 29, 2007 | 11:46 PM
the_merv's Avatar
Veteran: Air Force
The Balancer comes off, get a Hammer and tap it around a little. Then get a Puller and pull the Hub. It might be easier to put the Bolts back in and pull it out as one piece..
Old Jul 30, 2007 | 12:07 AM
alconk's Avatar
Awsom!! I'll try that, thanks!
Old Jul 30, 2007 | 01:24 PM
Pampered-Z's Avatar
here is some more info.
http://www.njfboa.org/forums/showthread.php?t=26204
