Where do these alternator wires go?
Old Jul 31, 2007 | 07:07 PM
Built LT1's Avatar
Default Where do these alternator wires go?
The alternator has one wire that plugs into it. In the wire loom however, it has two additional wires (black and green) that are hanging there. They were cut loose during a motor install. Are these wires supposed to go somewhere in order to properly charge the battery?
The car is '94 Z28.
Old Jul 31, 2007 | 07:14 PM
hpmotorsports's Avatar
should be a/c compressor wires
Old Jul 31, 2007 | 07:18 PM
Built LT1's Avatar
It looks like my alternator is not charging. When I removed the alt to get checked a local part strore, it passed twice with no issue.
I did eliminate the A/C so that does make sense.
Back to square one.
Old Jul 31, 2007 | 07:21 PM
Revelation Z28's Avatar
you should have the thick hot wire thats held onto the back by a nut and a connector from the harness for the regulator. seems like thoes wires for the regularot harness were cut and the battery isnt charging.
Old Jul 31, 2007 | 08:16 PM
lethal93ta's Avatar
do you have 12 volts to the little wire with the key on? that little wire is ran to the instrument cluster, if the instrument cluster is pulled or you have aftermarket gauges it will not charge.
Old Jul 31, 2007 | 11:32 PM
Built LT1's Avatar
I have one red "hot" wire held on the back of the alt. Is there more than one that goes to the back location?
Old Aug 1, 2007 | 12:18 AM
nope. then the other is a connector on the bottom corner of the back for the regulator
