biggest cam
Old Aug 8, 2007 | 12:19 AM
93blacktransam's Avatar
Default biggest cam
ok whats the biggest cam pretty lopey i can run with my stock internals on my lt1. like atock springs lifetrs rockers all that. or a kit for under 400 with it all and under 400. and how hard are they to put it can i do it in my home garage.
Old Aug 8, 2007 | 12:30 AM
ZONES89RS's Avatar
In-Zane Moderator
Gotta see what lift you springs will take.
Old Aug 8, 2007 | 12:54 AM
StealthFormula's Avatar
You cant have a lopey cam really without replacing other valvetrain considering most of the cams that sound lopey are too big for stock springs. You could get away with stock rockers if you wanted but it would be a good idea to get new lifters if you have a good amount of miles on your car. I think it would be a waste to do a cam swap without doing everything cause id personally rather do it all once and do it right and not damage the motor by running a lopey cam that has a lift greater than the stock valvetrain can support.
Old Aug 8, 2007 | 12:57 AM
ckyconan2003's Avatar
hotcam is the biggest, u can do it for under 400 bucks, and in your garage in a day.
Old Aug 8, 2007 | 01:52 AM
ZONES89RS's Avatar
In-Zane Moderator
+1
Old Aug 8, 2007 | 02:53 AM
daniel6718's Avatar
even a hotcam need new springs...id do a simple cc306 mail order tune and crane 10308 springs with stock rockers lifters and studs....in 2 weeks or when you get some money get some 1.6rr and 7/16 studs and guideplates and youll be set
Old Aug 8, 2007 | 12:22 PM
hotcam was desgined to work with the stock motor and stock tune, you dont need new internals at all, per GM. Yur not gonna run 11's but you will notice a difference in sound and power
Old Aug 8, 2007 | 01:20 PM
ive got the gm hot cam new spring lifter stock rockers.
Old Aug 8, 2007 | 04:33 PM
zlover129's Avatar
A cam without new springs is like breaking the home run record after using steroids...sure you can say you've done it but its just not the same
Big cam done right > Small cam no springs
Hank Aaron > Barry Bonds
Old Aug 9, 2007 | 08:42 AM
sam95transam's Avatar
zlover, good to see another CFB member on here. Not to get sidetracked but are you goin to the AutoFair this fall?
Old Aug 9, 2007 | 02:28 PM
infinitebird's Avatar
ANY aftermarket cam is too big for stock springs.
Old Aug 9, 2007 | 02:38 PM
GreatWhiteZ28's Avatar
+1, New cam = New Springs, The LT4 Hot cam kit is what? close to or a lil over $500 and has, cam, springs, rockers? I was considering this but then I decided to go with a bigger cam. and am happy with my choice. as said before, save up your cahs and do it at once, cause trust me, once you do it once, you're not gonna want to do it a 2nd time...
Old Aug 9, 2007 | 08:38 PM
onebadbird96's Avatar
hes a 17 year old kid he dont know his dick from a hotdog much less anything about cars
Old Aug 9, 2007 | 09:02 PM
96capricemgr's Avatar
The springs in the HOT cam kit work OK with the light weight LT4 valves but the LT1 valves are heavier and to get the most out of that cam you need more spring, even then it is only servicable, not great.
This is a big mod with a lot of costs besides the actual cam. Don't do it halfassed, save a few more bucks and do it right.
Old Aug 9, 2007 | 09:28 PM
96lt1m6's Avatar
damn,i wish more people would have your logic!
Old Aug 9, 2007 | 10:40 PM
zlover129's Avatar
I'm not sure at this point, i think im definitely going to be there, not sure about showing or not. We're thinking of possibly renting our own booth this fall but we're not sure yet, also depends on the car. Unfortunately my luck last year after the show wasnt the best haha.
Old Aug 9, 2007 | 11:46 PM
raroz28's Avatar
Go custom. A cam isn't something you "budget." Wait until you have the money to get what's right for you and then do it.
If you're sticking with a stock bottom end, get a custom grind that will make you a lot of power from 2000-6200 RPM. A lot of those off the shelf grinds don't even wake up until about 4k, and you gotta run them to 65-6800 RPM.
Lots of power but you're just asking for a spun bearing with that.
Old Aug 11, 2007 | 05:49 PM
scorpion_z28's Avatar
The problem is who makes custom cams,Bret??
catch him if you can.
Le,only sells his cams with the Heads.
Any others you know?
Old Aug 11, 2007 | 06:08 PM
zlover129's Avatar
Ive got a custom cam from Advanced Induction, 224/234 .567/.577 on a 110 LSA. I ******* love it, beats the ground, runs strong, and is extremely streetable.
Old Aug 11, 2007 | 06:31 PM
eLTwerker's Avatar
What's your idle like? Any track or dyno #'s with that cam?
Also, can anyone give me the valve events and overlap @.050" of that cam?
Thanks!
