LT1 heads question
Old Aug 8, 2007 | 11:14 AM
crz28's Avatar
Default LT1 heads question
My camaro lt1 made 365rwhp on full bolt ons and a cc306 cam, i'm taking the heads off to have them ported also the tb , my question is what kind of hp gains can i expect from these job.
Old Aug 8, 2007 | 11:32 AM
ZONES89RS's Avatar
In-Zane Moderator
Depending on who does them, how they do them and what you tell them you want from them, total with a valve upgrade full port and polish i have seen 40hp or more depending on the heads.
Old Aug 8, 2007 | 11:58 AM
lt197formula's Avatar
Don't forget to have the intake manifold ported for the throttle body and the runners port matched to the heads. If all that is done along with a good port job on the heads, larger valves you should around 35-40rwhp.
These numbers are for an m6 which I'm guessing you are, if you are an a4 then around 10 or so less.
I had my stockers ported, larger valves, runners slightly ported and gained around 30rwhp over some slightly ported heads. Then did a 58mm, ported intake manifold, more porting on the runners, 30lb injectors, retune and gained almost 15rwhp...and I'm using the same cam.
Old Aug 8, 2007 | 01:35 PM
speed_demon24's Avatar
Anywhere from 0-60rwhp.
