what is that noise??
Old Aug 10, 2007 | 09:24 PM
lilblackZ28's Avatar
Default what is that noise??
When i am going in reverse there is like this whining howling noise..Is that normal or is something wrong with my rearend or transmission?Thanks
Old Aug 10, 2007 | 10:15 PM
DeltaT's Avatar
Something is wrong and you should check it out before driving more.
Jim
Old Aug 10, 2007 | 10:17 PM
the_merv's Avatar
Veteran: Air Force
A4 or M6..
Old Aug 11, 2007 | 09:03 AM
Its an A4
Old Aug 11, 2007 | 09:15 AM
Scrapin'4.8's Avatar
Check ur bellhousing bolts. I had a jeep one time that two bolts on one side had come loose just a little bit and had the tranny at an angle and would whine, tightened em up and everything seemed fine for a while, but the it had twisted the tranny too much and ruined the front pump and seal. Never was right after that
