Est. Horse Power?
BBK TB Ported
Moroso CAI
TB bypass
underdrive Pulley kit
airfool
What should I expect with these items..Stock other than this stuff
After I get my headers im looking to ad the Fuel pressure reg.
BBK TB Ported Almost pointless on a stock engine
Moroso CAI
TB bypass
underdrive Pulley kit With the cam driven waterpump these stand to offer little gain and will compromize charging.
airfool Again nearly pointless and I think all the good aftermarket TBs have them built in when you eventually make enough power to warrant a bigger TB.
The regulator IS NOT A POWER MOD, if you think it is STOP buying parts right now and start learning before you waste more money on useless junk.
Of the 7 mods you listed here 4 are either not worthwhile at this level or are just plain not worthwhile. I strongly encourage you to stop looking at catalogues and start researching things better. You need to understand that just because some 20yo kid says a part is "great" but has no proof does not make it a good part. Egos make a lot of guys push their mistakes onto the next guy rather than being a man stepping up and admitting it was a mistake.
Take the money I hopefully just saved you and put it towards a good catback behind the headers(great mod), tuning, gears, maybe a little suspension. Then start to think about things like a torque converter like a nice 9.5" Edge or Yank 2800 or higher stall, they really do drive quite well and make a big impact on performance.
I forgot to mention , I'm not sure what sorta power or performance to expect out of my exhaust :
Stock manifold & Y pipe, no cat, and 3" from the y back with a dynomax bullet dumped over the axle.
The headers are next along with gears.
Really im only looking for around 300 horse, its a dd.
thanks
Just Kidding Mark
By the way, www.ws6.com gained 15 HP or so with the Fuel REG, i know it was due to a leaner mix with it, but it still did gain power, a tune would do the same though.
Not sure if I believe it though.
I have also heard countless reports of Ported TB's gaining 4-7hp on bolt on cars with crisper throttle response.
This I do believe.
This I do believe.
