383 LT1 Stroker coming soon.....
So let me know what you guys think. Thanks! James. Adding cubes and keeping stock heads is competely *** backwards and the car will not perform. Power is in airflow and the heads accomplish that. Heads and cam cars with stock shortblocks will walk all over a stroker with as cast heads.
The AFRs, especially the ones under 210cc have long SUCKED, they have a new line out(eliminator) because they knew their heads sucked but the new stuff is not really well tested yet. The AFRs were good upgrades on gen 1 motors because those heads were so bad from the factory, the LT1 heads were a BIG step forward and AFR just reused the outdated gen ports in their LT1 heads. They also weigh near what iron heads do.
Porting the stock head would be your best choice, I recommend Advanced Induction.
And go with a larger cam, that cam is a little small for a 383 imo.
Only way I would look at aftermarket castings is is you need a big chamber. Then again I look at things based on ACTUAL results as opposed to what is supposed to work, the more experianced you become you will learn those are two VERY different things.
I would let the heads guys help pick a cam but honestly low 230s might be a good intake duration for a DD/weekend warrior. I think a lot of folks here are FAR too quick to push too much cam, but that has been a hotrodding disease forever.
It'll also save you the hassle of having to deal with the downtime it will take to build the motor that's already in the car and having to be without it for however long it takes.
Bare LTx blocks can be had fairly cheap.
For a point of reference my cam is a 226/234 .568" and I was initially "poo-pooed" for going way too small for a 383...Those same folks are the first to run up to me at the track in disbelief at how quick and fast the car is and its all over by 6300 rpm...Just remember that its all in the combo. Everything has to work together...Its not hard, just takes a wee bit of planning...
--Alan
And hope to have it done by the beginning of next year. Wish me luck...I'll keep u guy's posted. And any further advice would be awesome as well as dyno #'s and setup info. Appreciate it..... James 383 Stroker Bottom End
4340 Forged Eagle Crankshaft
4340 Foged Eagle 6 inch H-Beam Rods
4340 Forged Speed Pro Pistons 10.76:1 w/64cc head ( Have the block decked and the heads will be cut a little as well to make sure they are straight.) Also since the stock heads are 54cc's the compression should be 11.5+ to 1 compression.
Also the block has been completely gone through- bored and honed, decked, magnafluxed, checked for imperfections, cleaned, and new freeze plugs and cam bearings installed.... Getting ready to put it back in the shop for the Splayed main caps and align bore to be done....
Also got new rings and bearings ready for build as well.
I have a few pictures on my myspace page in the album called (My Formula)
Feel free to check out the pictures of the motor so far....I will add more as I can get them....Since the guy building my engine lives 20 minutes away (on the highway), it's kinda hard to get out there for pictures. I'm always busy so I'll try my best...But thats my progress so far.....hope u like my setup.....Also going with a LE2 package for the top end forgot to add that up there^.......James
