valve spring question
Old Aug 13, 2007 | 11:17 PM
iceman15's Avatar
Default valve spring question
How do you test what lift a valve spring is good to. I got some aftermarket springs and dont know what lift they are good too
Old Aug 13, 2007 | 11:44 PM
SincalT/A's Avatar
find out your installed height for the given spring.then bring it to coil bind height measure that - .080 to .100 then subtract your # from the installed height that will give you a safe place to start.i say .080 to .100 cause spring manufacturers very in what they consider safe clearance.
