Header Bolt Threads In Head Stripped
Now he didn't put the bolts all the way in but enough to mess up the first half of the threads I think.
Is it possible to maybe just re tap it with the head on the car? I'd really hate to rip the heads off after i just got them completely on.
Any advice would help.
Thanks.
,Nick
you might be able retap the threads, but its highly doubtful they would hold any useful torque. if he got the bolt half way in with it crossthreaded, the bolt holes are more than likely screwed.
You'll need to pull the head and heli-coil it. The tightness and heat that these bolts see dictates that all the threads be good. Once threads are torn up, there's no magic way to put them back.
When you're ready to try it again, use a better bolt that'll hang in there and is easier to install:
https://ls1tech.com/forums/showpost....45&postcount=6
Good luck!
