My CC503 Dyno #'s
I would look into a converter though, it would help your car out a lot...Check out something that stalls between 500-900 rpm below your torque peak....
--Alan
--Alan
Autos dont need 400rwhp to run good times. An auto with lots of stall+gear with 320hp to the wheels will surprise the hell out of a 400rwhp 6speed in the 1/4.
Also, the area under the curve is very important. Dyno curves that look like the side view of an arrowhead are no good for the track, and no fun on the street.
like everyone else says, numbers on the dyno don't matter. numbers on the track do.
Are there other cars that have dynoed at the same shop that you can compare yours to?BTW, When you put a converter in it your numbers will probably go down, but your performance will improve.
HVY SS
anyone think my 328rwhp thru the auto is low im wondering if id benefit from having someone else tune it?
and no you numbers sound about right, take it to the track. if it does not perform well there then think about another tune.
