93' 355 Dyno Graph And Vids
Old Aug 20, 2007 | 10:15 PM
Blown93Z28's Avatar
Default 93' 355 Dyno Graph And Vids
Went down to Bristol Dyno to see what the camaro would lay down .. Bascially all i have done is a stockish rebuilt 355 with long tube headers, off road 3inch y pipe and a hooker catback. Stock cam, stock untouched heads etc ..
282HP and 310TQ
Def a great time .. Looking at the graphs, it looks like i have a spark/mis fire issue around 5500 so ill have to work on that ...
Dyno Videos
Sean
Old Aug 20, 2007 | 10:28 PM
V8sounds's Avatar
that's a solid torque curve right there.
fix that spark issue, and i bet you'll be close to 300rwhp.
then go get a set of heads and a cam, and be looking at 375rwhp.
looks like a nice setup.
Old Aug 20, 2007 | 11:18 PM
donkey mule's Avatar
I was thinking you should be closer to 300rwhp. Must have been the misfire?
Old Aug 20, 2007 | 11:49 PM
Blown93Z28's Avatar
Yeah im really happy with the numbers considering whats done. I was exspecting alil less actually. Def a tight motor . You can tell between shifts ....
Yeah the misfire issue is def holding alil bit of power .. I dunno where to start to look for the problem .. Plugs?
Sean
Old Aug 21, 2007 | 12:09 AM
ZONES89RS's Avatar
In-Zane Moderator
Guess 5750 is your sweet spot to shift.
