LT1 still overheating at idle
Old Aug 21, 2007 | 09:08 PM
Black94Z28's Avatar
Default LT1 still overheating at idle
thought i fixed the problem by putting the 180 thermostat back in, but the temp goes from 225-235 to around 245-250 at stoplights or idle. i opened the bleeders but a stream shot out. I have about a 80/20 mix of water/antifreeze in there, but that shouldnt be the problem right? I ordered a 160 stat that should be in tomorrow, but i feel somethings not right. Any ideas. It seems fine when i'm driving it, just at idle it starts overheating. I can hear the fans come on around 230ish.
Old Aug 21, 2007 | 10:15 PM
Z28_DAD's Avatar
take it to speed and have them program the fans to come on sooner. also ask them what else can be done with a basic GM tune for an OBD1 auto LT1. i know they did a few tricks on my M6 LS1
Old Aug 22, 2007 | 06:14 AM
Black94Z28's Avatar
how much did they charge you to tune it?
Old Aug 22, 2007 | 07:02 AM
Z28_DAD's Avatar
i think it was $150. it was awhile ago, so i could be wrong
Old Aug 22, 2007 | 04:36 PM
Burning Rubber's Avatar
Are the fans even coming on?? Does it only get hot at idle or is it also getting hot driving down the road?? If it is only getting hot at idle I would venture to say you have a problem with the fan. If it overheats when you are moving I would say probably a water flow problem or air in the cooling system.
Old Aug 22, 2007 | 06:53 PM
Zralou's Avatar
The temps you've posted are about right for an f-body with factory fan settings. These cars were designed to run way too hot as an attempt to keep emissions low.
Z28_Dad has the right idea, you need to get the fans re-programmed to turn on sooner (or install a manual switch). Also check that BOTH fans are running when you hear them kick in.
Sara Lou
Old Aug 22, 2007 | 06:56 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, i have mine come on with the ignition on my third gens, might do the same with my 95 after i get it back together.
