cam question
Old Aug 22, 2007 | 12:47 PM
crz28's Avatar
Default cam question
Is there any way to find out what type of cam an lt1 has with out taking it out of the engine
Old Aug 22, 2007 | 02:13 PM
the_merv's Avatar
Veteran: Air Force
Nope..unless it's a fresh Engine and you get the Buildsheet with it.
Old Aug 22, 2007 | 02:20 PM
ws6_z28's Avatar
If its a stock cam, yes. Otherwise you would have to degree the cam...
Old Aug 22, 2007 | 05:58 PM
seawolf06's Avatar
And the only plus is that you can degree it without taking the intake off. If you wanna take the cam out and look at the back to see a grind number, then you'll have to take the lifters out. Even then, there's no guarantee that we will know what the grind numbers mean.
Old Aug 22, 2007 | 07:26 PM
ZONES89RS's Avatar
In-Zane Moderator
If it idles normal it is stock, if it is verry radical, you can call it "BIG". Other than that, nope.
