LT1 swap
I have an 83 Trans Am with the anus of all gm's engines(LG4 305), but I just bought an LT1 that I was told was from a 95 Camaro, when I got there I knew it wasnt but then he said if was from a 95 Caprice, which sounded right since it had iron heads. I looked it over and the plugs looked good, oil good, and the casting numbers checked out as 94-96 5.7 LT1. So I went ahead and bought it. It had no accessories or even the bracket. But it did have the water pump and opti still intact so thats a good thing. Anyway let me get away from the gibberish.
I decided to verify exactly what I had before I start anything on the engine since I wanted to tear it down and at least check it out good, and at the least put new bearings in. So I was trying to find out the exact model year and figured I could do that with the ecm. I got the numbers and did some research and sure enough the guy didnt even know what he had. Turns out the setup is from a 96 OBDII Caprice. Now I have no frickin clue where to go from here. I was counting on OBDI so it would be easy to install and run and such, but with the OBDII I have no idea what to do. So should I sell the OBDII pcm and harness and start looking for an obd 1 setup, or would I be better off adapting the obd 2 system to my swap. I wont have any emissions, no trans sensors since its gonna be hooked to a T5(for now,t56 later), and basically just the bare minimum to make it operate properly. Also does anyone know where I could get a diagram of the OBDII 1996 LT1 harness so I can figure out exactly where everything goes. And how can I bypass all the stuff I cant use or wont be using? I thought about buying a new harness and a used obd 1 computer but the prices are just insane. And I dont even know if I can use an obd1 harness on the engine since it was made for obdII ?
I need to get this situation sorted out asap, since my car is just sitting due to major engine problems, and I am needing to get the LT1 dropped in and drivable.
i hate to do it because its just stupid and makes little sense but I am almost to the point I am gonna have to buy a carb intake for the engine just so I can get it running. But I'd hate to do that to an LT1. If that were my plan I woulda just got a gen 1 sbc. why have an lt1 if your gonna carb it...lol
sorry for the long post, but I am just flustered, and needing some really good and sound advice. I need to get through this the cheapest I possibly can. I have about 1500 dollars left to take care of all the small stuff, and still have to buy the acc. bracket, all the accessories, mounts, intake ducting, fuel pump, MAF(maybe, hoping to avoid it), and just a crap load of other misc. little bs that always seems to pop up while doing a swap, especially from a carbed non-cc to a late model fuel injected setup.
I will appreciate any and all info/advice given. And again sorry if I'm intruding. I've just always heard this was the place to go to find knowledgable people. I'm always hearing good stuff on other sites about this place so I figured I'd give it a shot.
Also if I were to do that, I would want to make sure I have everything I need before I go through that expense. by the way the harness looks, I dont even see how I would hook up to a diagnostic connector, it doesnt have a port on it and oh hell, I am so frustrated with this damn thing. It would be nice if I could just get a damn schematic of the harness so I'd actually know what the hell I have and whats missing and all that. I'll try and post pics so you will know what I mean.
its really not bad doing it yourself. i also have the engine harness pinouts that i got from the dealership which are a little easier to read. they are for a 96 fleetwood w/lt1, but its the same for the impala. if you have a number i can fax them to, pm me and i will
I did get lots of pics today, but I need to get to bed so I'll just post the two that show the connectors that i am most interested in knowing what are:
