My car is running rough
Old Aug 29, 2007 | 08:19 PM
My94TransAm's Avatar
Default My car is running rough
My car has been running rough at idle and under a load (really only uphill). It still has all the power I think. The volts were reading in the yellow so I put a battery in it and had the alternator checked, which turned out to be ok. I couldn't see anything visual. I have had a plug wire get split before and this is almost the same feeling. Any suggestions?
Old Aug 30, 2007 | 08:56 PM
Noone knows or has adivce?
Old Aug 30, 2007 | 09:42 PM
ThoR294's Avatar
check the condition of your throttle body and IAC passageway?
Old Aug 30, 2007 | 09:48 PM
infinitebird's Avatar
Sounds like ignition.
Are you able to check the condition of the wires?
Have you ever burned one on your headers?
Old Sep 3, 2007 | 08:02 AM
What do you mean burned one of my headers?
Old Sep 3, 2007 | 08:34 AM
ThoR294's Avatar
i think you would burn a valve before you burned your headers. did you look at your throttle body yet? and timing could be a problem, but you always want to check the easiest **** first
Old Sep 3, 2007 | 02:04 PM
I said have you ever burned a wire ON the headers, like had a wire touching the headers. That's a common issue with headers.
Old Sep 3, 2007 | 04:56 PM
transam5.7lt1's Avatar
It sounds like its in need of wires, just like evryone on top suggested.
Old Sep 3, 2007 | 05:07 PM
blk97z28's Avatar
Wires ???!
Old Sep 3, 2007 | 05:08 PM
blk97z28's Avatar
for the win!
Old Sep 3, 2007 | 09:56 PM
I checked the wires. They all look like they were in tack. And yes I have had a wire burn before on the headers. This feels like the same thing, but like I said I didn't see anything wrong. I'll look again next weekend.
Old Sep 4, 2007 | 02:53 AM
Ralls's Avatar
It does sound like ignition. Check the resistance of each wire. It's typically 5,000ohms for every foot. Make sure the ends of the wires aren't all corroded. Check the coil wire too.
