help with lt1 heads and cam
Old Sep 3, 2007 | 04:24 PM
powers84's Avatar
Default help with lt1 heads and cam
i just got some heads that have a mild port and polish done but i was woundering on the springs, im not sure on what ones to get i need help if you have part numbers it will help so far i have the lt4 hot cam 1.6 RR's and i plan on getting the CC306 cam, what should i get
Old Sep 3, 2007 | 06:31 PM
396D1SS's Avatar
I would use comp beehive springs part# 26-918-16
comp retainers part# cca-787-16
shims part #cca-46753
if your keepers are in good shape reuse them they dont really go bad
that is more then enought for a cc306 and overkill for a lt4 hc but you will never have to worry about valve float
9formula4's Avatar
I run the Crane 10308s They are good to .610 lift and are rated at 408 psi
Old Sep 3, 2007 | 06:32 PM
396D1SS's Avatar
btw summitracing is the cheapest place to get em
Old Sep 6, 2007 | 06:17 PM
powers84's Avatar
thanks i think im going to get a 383 short block if im lucky
By Brett Foote | 2026-06-04 05:00:17
