My luck - could use a little help
I haven't had a chance to get under and look for where it goes to, or to fully inspect passenger side wires, but my main question is where I can find detailed instuctions for changing the plug wires on my car. It is a 94 v8 car. I need to know which spot on the distibutor goes to which spot on the engine. I can't take one off at a time to matych them up when 3 are just plain cut. I don't want to do any damage with the wrong order. I don't even know where the distributor is on my car, i guess i would follow the wires back to it. For anyone saying read the numbers on it, I'm guessing that on an old car oil and dirt have covered them up and its dark under a car in my driveway. I wouldn't know which cylinder is which anyway. So far I can't find much, can anyone help me? I figure it should be an easy job though once I know what goes to what, plugs should just pop off and pop on with no tools but idk if clearance is an issue. Can I do it with my car on blocks in my driveway? or do i have to have somebody tow it and do it in a shop? How tight of a squeeze is it with your hands and arms? Any help or info is greatly appreciated.
also- the green mystery wire I was talking about was in its own loom drivers side between the exhaust manifold and the fender, from the back to front,and looks like it may have ran parallel to a red and yellow wire in their own loom if anyone knows what this could be and where it goes.
