ls7 clutch pressure plate & flywheel on lt1 ????
Old Sep 7, 2007 | 05:00 PM
transam1577's Avatar
Default ls7 clutch pressure plate & flywheel on lt1 ????
hi i just wanted to know if you can use an ls7 clutch and pressure plate and even the flywheel on a 1994 transam m6 and also how much power will it hold
Old Sep 7, 2007 | 05:04 PM
Revelation Z28's Avatar
i wouldnt think so because our starter had a different amount of teeth than the LS starter. also the flywheel bolts may not line up unless you get one of thoes universal hole flywheels. and our clutch release system is a "pull" type, and not a push type.
Old Sep 7, 2007 | 08:27 PM
speed_demon24's Avatar
Nope.
Old Sep 7, 2007 | 09:31 PM
nighthawk15's Avatar
Not gonna work. The clutch designs for the two engines are night and day.
