need help with lt1 heads!!!
My question is, i have 107,000 miles on my heads, can i just get my stock heads re-worked, valve job,etc..and run 12 psi fine? because if i get aftermarket heads, the compression will be alot higher so i wont be able to run as much boost..
Also, if i just re-work my stock heads, how will my head gaskets be? i mean im sure ill be fine but i have peope telling me i need aftermarket heads..like ported afr's..
General rule of thumb for most motors (from what lots of people have told me) is you want to run lower CR to run more boost. But the LT1 is a bit different from the rest of the crowd. He run 8psi now on the stock motor, so with the forged short block and assuming he left the heads and cam alone, could he still run 12psi with 10.5:1 CR?
And another Q to help him, should he get chrome-moly push rods and a new set of lifters? Like even just LSx ones with 30Kmi or so on them?
I would not go throwing big valves at it.
Seems that someone needs to point out boost is a measure of how much air IS NOT getting into the cylinders. Put good heads on there and run 8psi making more power with less stress on the front of the crank, belt, and blower using the same pullies.
