What sort of power would this setup make?
Old Sep 9, 2007 | 06:00 PM
V8sounds's Avatar
Default What sort of power would this setup make?
383 stroker
10.7:1 compression
LE stage 2 heads with a 230/230 .575/.575 112lsa cam
52mm throttle body
1 3/4 headers, ory, magnaflow
I was told that this cam would give me very good low-mid power, but i'm afriad it would fall off up top? expected redline is 6200-6400.
Old Sep 9, 2007 | 06:03 PM
Matts94Z28's Avatar
Why don't you get an LE2 or LE3 cam?
Old Sep 9, 2007 | 07:22 PM
infinitebird's Avatar
If this is an N/A motor you should increase the compression.
MEAN LT1's Avatar
Originally Posted by V8sounds
383 stroker
but i'm afriad it would fall off up top? .
our right, it will fall of up top. Why dont you get a custome grind cam or go with an LE2/3 cam like recomended. Your setup would make more power with the appropraite cam.
