I Need pics of engine being pulled from bottom!!! Please
Old Sep 12, 2007 | 01:57 AM
daniel6718's Avatar
it sure doesnt seem safe, ive done it about 8 times...get the back tires up in the air also...helps alot...makes it mre stable, get some bricks from lowes the rectangle bricks they are like 1 dollar a piece...put teh jackstand on top of that
Old Sep 12, 2007 | 02:03 AM
Mike96z's Avatar
well since i am now parting it and not selling it as a whole, prob be easier to disassemble it in the car and pull just block and transmission lol. Ive pulled from top so many times, only wanted to do from bottom so that I could sell the engine as a whole. Thanks
Old Sep 12, 2007 | 02:10 AM
daniel6718's Avatar
i would still pull it from the bottome..getting the headers and heads ect off is a sinch outa the car...im just telling you it would save tons of time...pulling the whole thin out the bottom only about 2 in a half hours...disassember it completely maybe an hour
Old Sep 12, 2007 | 02:14 AM
Mike96z's Avatar
I can do it in the car, if i have the stuff to do it from the bottom i will.
Old Sep 12, 2007 | 03:19 AM
Schweet97Z's Avatar
Here is my contribution
http://www.97transam.com/harold/hc.php
Old Sep 12, 2007 | 03:26 AM
skinnies's Avatar
Old Sep 12, 2007 | 03:30 AM
Schweet97Z's Avatar
Since the heads were milled the intake manifold bolt holes wouldnt line up. So we had to do alittle "fabricating"
Old Sep 12, 2007 | 03:39 AM
Mike96z's Avatar
thanks, yea moved the bolt holes a little lol.
Old Sep 12, 2007 | 03:45 AM
skinnies's Avatar
Did the intake ports line up correctly? To do that properly you need to mill the intake.
Old Sep 12, 2007 | 03:50 AM
Schweet97Z's Avatar
the heads were only milled .010. you know until now i never thought of it that way. you do make a good point. although im not tooo worried about it, because i feel the car is making great power. it put down 382 rwhp 368 rwtq through a loose stalled slipping auto (which broke the same day as the dyno tune), 3:73 gears, stock injectors, unported intake, and blowing out the spark in the upper rpms.
Old Sep 12, 2007 | 04:32 AM
Mike96z's Avatar
id pull that intake
Old Sep 12, 2007 | 05:11 AM
  #32
Schweet97Z's Avatar
its stayin right where its at. .010 of an inch isnt that much of a difference. it was just become hard to screw in some of the bolts, and i didnt want to strip/crossthread them into the heads. the intake ports line up with the runners of the heads just fine. the only time the intake will come back off is if i get it ported.
Old Sep 12, 2007 | 05:54 AM
  #33
Irocss85's Avatar
so those are LT1 heaeds? I was thining maybe you put some diff. heads on there.
the port job does look awesome though.
oh yeah, I still way DEF. now pull it from the bottom if you dont have to worry bout putting it back together. seriously dude, the headers/intake/heads/whatever is right there on a platter for you to dissasemble and you'll have it done in no time compared to in the car.
Old Sep 12, 2007 | 06:53 AM
  #34
Schweet97Z's Avatar
they are lloyd elliot ported lt-1 castings. thanks for the compliments, but the work was all done by lloyd, so he get the majority of the credit, i just opted for the awsome porter!
Old Sep 12, 2007 | 11:32 AM
  #35
Schweet97Z's Avatar
Irocss clear some of your private messages so i can reply to your pm.
Old Sep 12, 2007 | 11:39 AM
  #36
Irocss85's Avatar
sorry bout that. done dude. I know, Im an anchor.
