Looking at a 93 z28
Old Sep 15, 2007 | 05:24 PM
3800RS's Avatar
Default Looking at a 93 z28
Hey guys, Not too familiar with the lt1's in 93. I know they do not have the vented optispark but how are the motors over all ? Found a deal on one local and thinking about picking it up to use the motor for a swap project.
Old Sep 15, 2007 | 05:26 PM
ThoR294's Avatar
its an LT1. difference between 93s and the rest of the LT1s is a few things.
No vented opti like you said
Bank injection
Speed Density (no maf) which is probably better for u since you are swapping
if its a stick, it has a lower geared trans.
Old Sep 15, 2007 | 07:03 PM
3800RS's Avatar
its an auto, what exactly is the bank injecion ? are the heads u know cast iron or aluminum ?
Old Sep 15, 2007 | 07:07 PM
Speed Density's Avatar
hashtagBMW
Alluminum heads
Old Sep 15, 2007 | 07:26 PM
fireman's Avatar
Didn't they have the 700R4 instead of the 4L60E?
Old Sep 15, 2007 | 08:02 PM
Pampered-Z's Avatar
Everything said about is true. 93 Z's came in two flavors:
93s are batch fire, it fires all 4 injectors on the side and not the invidual cylinder.
Check if it has the 120 or 150MPH speed. If 150MPH it is a PEG II optioned car and has the 245 Z=rated tires and performance axle = 3.23s. If the speed-O goes to 120 then it has 235 none Z rated tires, 2:73 and a speed limiter of 110MPH ( <- i think that's where it's set ).
The things to check on 93s are the exhaust header bolts ( Drives rear and pass front are known to shear off. Also check the back on the manifold for the oil leak.
Old Sep 15, 2007 | 08:10 PM
ThoR294's Avatar
correct fireman. 94 they started the 4L60E
every LT1 has an iron block with alum heads.
Old Sep 15, 2007 | 09:04 PM
3800RS's Avatar
Thanks for the info so far guys. is it bad to have the 700r4 tranny ?
Old Sep 15, 2007 | 09:21 PM
Mojave's Avatar
That isn't right. The Caprices and Roadmasters got LT1's with iron heads.
Old Sep 15, 2007 | 09:22 PM
LT1Formula007's Avatar
700R4's are good transmissions in my oppinion, BUT even with a good build they still won't hold up as well as a 4L60E. But then again a 4L60E won't hold up like a 350/400 turbo either, It's all about preference I guess. They do however have OD which the 350/400 turbo's don't. I'd say if your not planning on making a whole lot of power, it will be fine. But you should put a stall,shift kit, and a cooler on it.....You'll like the way it reacts after that If you buy it, good luck, and get us some pics.......JAMES
Old Sep 15, 2007 | 09:31 PM
the_merv's Avatar
You guys keep sayin 700R4..I think it was actually called a 4L60.
Granted they are both the same pretty much, but I think that was the actual designation for it.
Old Sep 15, 2007 | 09:34 PM
3800RS's Avatar
Well i will see how things work out, prob take a look at it this week.
Old Sep 15, 2007 | 09:35 PM
ThoR294's Avatar
it was a 4L60. i dont know what the diff is between them... besides the labeling. 4 stands for how many gears.. L means Longitude (Rear wheel drive) and 60 is the torque/hp rating.
the newer monte carslows have the 4T60E. cause they were transverse (front wheel drive)
Old Sep 15, 2007 | 09:42 PM
the_merv's Avatar
60 is how many miles you can go before you start having problems..
Old Sep 15, 2007 | 09:44 PM
ThoR294's Avatar
problems..
haha. the vets had the 4L80E i believe... so they could go 20 more miles! bastards!
Old Sep 15, 2007 | 09:47 PM
the_merv's Avatar
Actually the Vettes have the same thing we do. The HD Trucks have the 4L80E..
I have a 4L65E in my Car..
Old Sep 15, 2007 | 10:00 PM
Smokeshow_2006's Avatar
Just a little fuel to the fire... 98 half ton has a 4L80E and a 14 bolt.. hahah
Old Sep 15, 2007 | 10:04 PM
ThoR294's Avatar
haha damn we got boned
Old Sep 15, 2007 | 10:31 PM
the_merv's Avatar
If you are a light-weight car..and have a Stall that isn't too crazy..they will last for a little bit.
