opti's suck
Old Sep 18, 2007 | 09:18 PM
cruzin94's Avatar
Default opti's suck
well my opti is going out and i was wondering if there is any kit that compltely gets rid of the opti to convert to coil packs instead of the ones that use the opti to run th coil packs and is there a way to convert a 94 opti (non vented) to a vented opti
Old Sep 18, 2007 | 09:24 PM
383lt1impala's Avatar
nope u still gotta use the iptis optical sensor i asked the same it sucks huh i just got a new one from jegs there less now
Old Sep 18, 2007 | 09:42 PM
cruzin94's Avatar
what opti did u go with and what is the best out there
Old Sep 18, 2007 | 09:44 PM
blk97z28's Avatar
Msd Pro Billit.
Old Sep 18, 2007 | 09:45 PM
blk97z28's Avatar
I believe it cost around 500 or so, you could do a DELTEQ setup or LTCC.
Old Sep 18, 2007 | 09:48 PM
mySlowLt1's Avatar
How many opti's have you been through? if it is a new one you should pull it apart and locktight the 3 screws on the inside. I have never had issues with an opti
Old Sep 18, 2007 | 09:51 PM
jasonisdn's Avatar
well i have the best luck with opticraps. lets see 2 msd's 1 bad out of box, the other was missing on 2 cylinders. factory opti lasted about 2 weeks hitting 7 grand a few times. now the LTCC looks like the next step. i have a guy that is local to me working on making a rear mount distributor to plug into the factory harness. he might have it done by the end of this year, he told me that yesterday when i asked about it. until then i guess some will have good luck with them and others, like me, won't.
