Header Installation... Need Some Advice...
ignore the first 5 or so pics
Don't get me wrong you will say a few curse words but its not that bad. Its took me 3.5 hours to do start to finish. If you you pull the valve covers it give you just enough room on the drivers side to snake it in there. The passenger side has to go in from the bottom and that is the worst side to do. Its definetly worth the abuse for the gain you get over the worlds worst exhaust manifold in the history of GM. Good luck Hope everything work out ok. Make sure you post how the true duels work! I thought about doing it to my 94. I am currently running 4inch. and it works but my car is lowered so it scrapes over speed bumps. If you need help let me know would be glad to help.
Apollo3
