LT-1 Ignition timing
Old Sep 19, 2007 | 11:20 AM
leadfoot4's Avatar
Default LT-1 Ignition timing
Anybody happen to know what the ignition timing should be for an LT-1 engine? I recently bought an Actron scanner that reads "live" data. Last night, I had some free time, and threw it on the car.
Initially, the timing figure read -50 degrees, while in closed loop. As the car warmed up, it went to -20 at idle and -40 as I drove under light throttle. As I accelerated, it went back to -45.
For the record, I have an LT-4 knock module in the PCM, but I left the OE LT-1 knock sensor in the block.
Any thoughts?
(thinking the reader might be wacked, I put it on my wife's car, and it showed timing numbers in "positive" numbers)
Old Sep 19, 2007 | 04:40 PM
MEAN LT1's Avatar
What kind of timing are you talking about?. Initial timing?,wot timing?, part throttle timing?.
Old Sep 20, 2007 | 04:47 AM
leadfoot4's Avatar
I mean the timing that the PCM is showing to the ADLD port, that the scanner is reading. It's -45 at idle, and varies between -45 and -25 as I drive the car, based on acceleration and/or load.
Old Sep 20, 2007 | 09:39 AM
Bird_Of_Prey's Avatar
That is TOTALLY normal. All that matters is timing under WOT. Everything else is just setup for fuel efficiency and driveablity.
Old Sep 21, 2007 | 06:20 AM
BlackScreaminMachine's Avatar
Internet Mechanic
if you had a laptop, id just get datamaster, I trust their readings alot more then Actron
