couple of sensor questions
Old Sep 19, 2007 | 07:18 PM
TrammelZ28's Avatar
Default couple of sensor questions
1. on the intake elbow i got an aftermarket elbow and it doesnt fit the stock air temp sensor without drilling for it. will this have any big affect on the car not having this sensor?
2. on the throttle body i did the coolent bypass mod. will not having that sensor do anything?(throw a code)
Old Sep 19, 2007 | 11:47 PM
LTwonZ's Avatar
1. Yes you need the IAC sensor so drill the hole a bit bigger so it will fit.
2. There is no sensor when you bypass the TB. Which one are you talking about?
Old Sep 20, 2007 | 05:52 AM
TrammelZ28's Avatar
that is the iac sensor i think. i mean i have it hooked up but i didnt know if not having the coolent run threw would throw it off or anything.The other one that goes into the elbow is the air temp sensor
Old Sep 20, 2007 | 12:26 PM
infinitebird's Avatar
No, that won't affect any sensors. The only purpose of that is to heat up the tb.
