O2 Sensor eliminator
Old Sep 19, 2007 | 08:14 PM
carjunkie33's Avatar
Default O2 Sensor eliminator
I just put Pacesetter header on my 96 Trans AM and theres no where for me to put the O2 sensor where they go (one infront and one behind the cat) because I dont have a cat anymore..I need to find an O2 sensor eliminator for my 96 trans am. I have tried googling for one but i cant find any? does anybody know where I can find two at?
Old Sep 19, 2007 | 08:37 PM
97blackz28's Avatar
if you have a 96 you have 4 o2 sensors. 1 before each cat, and 1 after each cat. you need the front two for your car to run, there should be an o2 bung on the inside of each collector for your front o2s. the rears can be deleted either by having them tuned out of your pcm or by running o2 simulators. most of the sponsors on this site will carry them or at least know where to get them from, so give the one you choose a call.
Old Sep 19, 2007 | 10:05 PM
which one are the front ones? the square ends or the thin oval end (Im talking about the connector thats connects to the wiring harness)
Old Sep 20, 2007 | 04:14 PM
97blackz28's Avatar
the fronts are the flat 4 pin clip and the rears are the square 4 pin clip.
Old Sep 20, 2007 | 07:39 PM
Maverick-WS6's Avatar
your pacesetters shoulda came with extra wire, i lengthened the o2 sensor wires to plug into the connectors, (i'm still looking for a harness for those) go to autoafterthoughts.com and buy the 02 simulators to plug into the rears. one by the trans and one up by the starter. good luck
