Double Roller Timing Chain
Old Sep 24, 2007 | 06:15 PM
projekt70chevelle's Avatar
Default Double Roller Timing Chain
Will be doing a cam swap (similar to the cc503) in the future and im planning on changing the timing chain. Do you need to make any changes to allow the lt1 to accept a double roller. Also will any sbc chain from comp cams work?
Old Sep 24, 2007 | 06:27 PM
Bersaglieri's Avatar
Have E-WP and 95+ Cover/Opti. You'll probably have to grind the cover a bit to get it to run without rubbing. Cloyes Double True Roller > Comp Cams
-Dustin-
Old Sep 24, 2007 | 06:39 PM
Okay. But will any SBC chain work for the LT1 or is there a special one?
Old Sep 24, 2007 | 06:47 PM
GMRACER13's Avatar
Any one should work as long as it's for a factory roller motor and you have an electric waterpump and a '95+ Opti as stated above. I have a Rollmaster billet double roller timing set and I had to clearance/grind the cover to make room for it.
Old Sep 24, 2007 | 07:06 PM
Well my car is a 95 so yes on the opti but i don't have an electric water pump. Just wondering but was there a lt1 that came stock with an e-wp.
Old Sep 24, 2007 | 07:33 PM
No, no cars come with E-WP's. You must buy one and pull the guts out of your stocker and bolt on the electric one. Cheap 10rwhp.
-Dustin-
Old Sep 24, 2007 | 07:34 PM
Formula350's Avatar
No. I don't know of any car coming with one, but then again I'm not all that knowlegable when it comes to euro-imports.
