High idle at start up???
Old Sep 25, 2007 | 11:39 PM
alconk's Avatar
Default High idle at start up???
I installed the LT4 hotcam and was very happy with it but now it seems that everytime you start it it revs up to about 2k than settles back down but takes about a minute. Is this normal?? Even when it's hot. My tune is from PCM4less and at first it wouldn't do that and also sometimes you can't even tell there is a cam in it. But if you sit at a stop light very long it will start to lope and sounds great.....
Old Sep 25, 2007 | 11:41 PM
Formula350's Avatar
Not sure... small vacuum leak?
Old Sep 25, 2007 | 11:47 PM
alconk's Avatar
No vac leak and it settles back down. Vac leak would keep the idle high. Could it be in the tune??
Old Sep 26, 2007 | 09:24 AM
Ls1Bait's Avatar
Whenever I start mine up when its warm it kinda revs up for a few seconds to maybe 1300 and then goes down to normal. I would like to tune it so it doesnt do it but I dont know what where I would have to modify my lt1-edit file?
Old Sep 26, 2007 | 10:00 AM
Jditlfm's Avatar
when i start mine cold it revs to 1700 and will stay their for a while if i just start driving i have to come to a stop and wait for it to come down. Then it idles at 800 rpm. I think maybe my IAC is going?
Old Sep 26, 2007 | 06:37 PM
alconk's Avatar
Yes I can see that when it's cold, it goes into a closed loop operation and is normal. I will have to call Brian and see what he thinks.
Old Sep 26, 2007 | 07:22 PM
ThoR294's Avatar
car is trying to heat up... higher idle = get hot faster
