What are splines
Old Sep 26, 2007 | 11:09 AM
crz28's Avatar
Default What are splines
I'm buying a locker but they come by number of spline, whats a spline and how do i know what number does my car has.
Old Sep 26, 2007 | 11:32 AM
buffman's Avatar
splines are a series of uniformly spaced ridges on a shaft, parallel to its axis and fitting inside corresponding grooves in the hub of a gear, etc., to transmit torque.
The number of splines will depend on what axles you have. I have no clue what the spline count would be on a ford 9"
Old Sep 26, 2007 | 11:45 AM
JHALL7644's Avatar
Thumbs up
Couldn't have said it any better
Old Sep 26, 2007 | 12:09 PM
borninatransam's Avatar
most likely you have 31, 33, 35 spline axles in a 9 inch. if you ordered the rear yourself you should be able to look on the build sheet for it and find out.
Old Sep 26, 2007 | 12:46 PM
crz28's Avatar
Thats the problem that this rear end was in the car when i bought it , now i'm buying a e-z locker and i need to know,i guess if i take it apart i will be able to see it right?
Old Sep 26, 2007 | 01:17 PM
Pntbll309's Avatar
Always.
Old Sep 26, 2007 | 01:19 PM
AR15 guy's Avatar
Take out an axle and start counting.
